3.0d cranking taking longer....
Re: 3.0d cranking taking longer....
Post by Bench » Tue Oct 26, 2010 1:21 pm
Had the exact same problem with mine. Turned out to be injectors too (had two replaced)....funnnily enough that was after i replaced 2 glow plugs and the battery lol!!!
Bench
Post by BL02WAS » Thu Dec 09, 2010 9:30 pm
bump
BL02WAS
Post by Smeeagain » Sat Dec 11, 2010 8:59 pm
in terms of sticky injectors does anything like STP, Redex etc work before resorting to replacing them. I'm going to give it a shot tomorrow and see it I notice any difference - would appreciate any thoughts anyone has on the effectivity of such products
Smeeagain
Post by BL02WAS » Sat Dec 11, 2010 9:08 pm
i personally wouldnt use any of that, not good. with regards to the injectors, there is a seal which fails that then allows blow by of fuel past the seal when warm, thus you lose the pressure in the rail and takes that bit longer to crank to start as it has to pressure and prime that line, off 7 bar fuel pressure, once engine and main fuel pump is running then there is pressure a plenty so no symptoms, but seriously wouldnt use these type of products, it wont solve it. you need to get them done
BL02WAS
Return to “Problems (E53 1st-gen, 2000-2006)”
Jump to
- Forum
- ↳ Forum Discussion
- ↳ New members section
- BMW X1
- ↳ General X1 Forum (F48 - 2nd gen : 2015+)
- ↳ General X1 Forum (E84 - 1st gen : 2009+)
- BMW X2
- ↳ General X2 Forum (F39 : 2018+)
- BMW X3
- ↳ General X3 Forum (G01 - 3rd gen : 2017+)
- ↳ General X3 Forum (F25 - 2nd gen : 2011+)
- ↳ General X3 Forum (E83 - 1st gen : 2003+)
- BMW X4
- ↳ General X4 Forum (F26 - 1st gen : 2014+)
- BMW X5
- ↳ General X5 Forum (G05 4th-gen, 2018+)
- ↳ General X5 Forum (F15 3rd-gen, 2014+)
- ↳ General X5 Forum (E70 2nd-gen, 2007-2013)
- ↳ General X5 Forum (E53 1st-gen, 2000-2006)
- ↳ Problems (sub-forums for all models)
- ↳ Problems (F15 3rd-gen, 2014+)
- ↳ How-To
- ↳ Problems (E70 2nd-gen, 2007-2013)
- ↳ How-To
- ↳ Problems (E53 1st-gen, 2000-2006)
- ↳ How-To
- BMW X6
- ↳ General X6 Forum (F16 2nd-gen replacement, 2014+)
- ↳ General X6 Forum (E71 - 1st gen : 2008-2015)
- ↳ Problems (sub forums for specific models)
- ↳ Problems (E71 1st-gen 2008-2014)
- ↳ How-To
- BMW X7
- ↳ General X7 Discussion (G07, 2018+)
- General
- ↳ General car-related discussion
- ↳ Gallery
- ↳ Meets/Events
- ↳ The lounge
- ↳ On the light side
- ↳ Other Marques
- ↳ Buy and sell
- Links
- ↳ Z4-Forum
