How many days since your last problem?
rhinoman
Re: How many days since your last problem?
120k when bought, full history, 134k now, One year of ownership.....
Service and breather replaced.
Recon gearbox
New battery
BM54 repaired
Speakers upgraded and sub/amp added (cause they were rubbish)
4 Tyres
Brake pads all round
New wipers front and rear + e70 rear arm
Wouldn't start - fuel injection relay replaced
EGR fault, cleaned
Front suspension lower upper thrust arms, links and arb bushes
Drivers door handle
Rear upper arms
Rear Subframe bushes and arb bushes and links
Rear number plate light faults
Rear stop/tail light bulb faults
Radio signal was rubbish, went off with the heated rear screen, cleaned up all the aerial connections
Countless alignments in between the suspension parts
Battery leak problem (think it was the rear lights seems ok now after testing)
Bumper repair (somebody didn't see it parked)
-Next rear lower arm bushes to get the rear camber in spec
-still to do drivers heated front seat doesn't work.
Keep telling the wife, it'll be al-right for a while now.....
Recon gearbox
New battery
BM54 repaired
4 Tyres
EGR fault, cleaned
Drivers door handle
Rear upper arms
- Steamyrotter
I haven't enough bandwidth available to post my list!!!!!
>:D
>:D
Please note...
Please note...
[quote="Steamyrotter"]
>:D
You need a forum of your own....... :'( :blink:
Something like "BeingMendedWeekly" perhaps?
>:D
Zakbelle
Did anyone on here buy cheap with known issues or all FSH and good history?
- Reusch
- Contact:
Bought mine cheap private.
Door handle.
Battery.
Hedgehog.
Repair BM54 Unit.
I'm sure there's more.
Door handle.
Battery.
Hedgehog.
Repair BM54 Unit.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
- Sim0x
- Contact:
Mine was today, got a nice little indication on the BC.................. WASHER FLUID LOW!
PHEW! that could have been worse lol
- Spartanx5
I brought mine with FSH and some known faults ie rocket cover gaskets leaking, then to top it off, I caused some problems by putting different tyres on the rear compared to the back, BUT everytime I look down on people at traffic lights or roar through tunnels I seem to forget that it ever has problems, I even refer to her by name in conversation on occasion
4.4 silver on chrome 22s
I bought mine brand new and within days the problems started (built Xmas 2004).
Driver's door did not fit properly. Adjusted.
Oil pressure sensor faulty - replaced
Near side mirror failed - replaced
Coolant temp sensor faulty - replaced
Speedo fault, stopped working - dealer took binnacle out and did summat to make it work.
Oil level sensor failed - replaced
Power steering hoses leaking - revised version fitted.
Sunroof fault - adjusted
Satnav GPS receiver intermittent. Replaced
Oil pressure sensor failed again! Replaced
Rear washer pump failed.
Pano roof rear section started 'popping' - parts replaced.
Coolant loss - dealer found a leak somewhere
AC fans in dash for very noisy - at least 2 replaced due to bearing failure
Driver's mirror motor fault - replaced
Boot lock causing electrical issues - replaced
Starter Motor 'over current' draw - replaced
Rear washer nozzle blocked - replaced
Gearbox failed at 38k miles - repaired
Fuel pump relay failed - replaced
Enough was enough.....got rid!
storminmike
Mine had a car run into the rear bumper...just scuffed and killed (punched in) two parking sensors
Insurance job (non fault) will see it get a whole new bumper complete with a pro done colour code to the lower edge to mimic the "is" look. I'd painted mine already...so they'll do the same
New bumper...BMW said the scuff to the black bit was more trouble that it was worth to sort....i'm not paying so hey ho
check oil level pings occasionally after long run...but the oil level is fine
Chrisw4266
Well about 26 hrs now since I changed the oil filter housing gasket. So fingers crossed.
Has had right rear height sensor link arm on Tuesday. Replaced both rear tyres Saturday. Fixed folding mirror micro switch Sunday.
Replaced dash LCD screen Thursday last week.
Only had the car 3 weeks, oh and it's booked in for a new clutch on Tuesday. Did somebody say money pit?????
Zakbelle
Chrisw you must have got it cheap with all of those faults or just incredibly unlucky
- Spartanx5
So I went to see mine today after i sent it back to the garage for an oil leak, the first week I got it I had 2 new rocker cover gaskets fitted and the new leak is on a bit at the very front of the engine, it's almost the rocker cover but it's a small metal box sort of underneath the rocker cover gasket but imagine your looking directly at in from looking front on, i saw the new gasket which hopefully is getting fitted tomorrow, it's a half moon type gasket. Long story short still not sure if this problem was caused when they did the first gaskets or not but hey, new wheels arrived aswell today so they will go on tomorrow to. and then I just sit back and wait for the next thing. Ha
Chrisw4266
[quote="Zakbelle"]
Cheapish but thankfully I budgeted to stick a grand into it in the first year. I've worked for a bmw Indy garage and know most BMWs need £500-£1000 spending each year. E46s,E39 high performance stuff seemed to be the worst.
The clutch is through choice it only slips a tiny bit if you floor it from 30 mph in 3rd or 4th. I'm towing over the next few weeks I couldn't risk a breakdown with the wife and kids with me. Has done 137000 so expect it needs one any way. I've just removed the CDV off the slave cylinder and it changes much nicer now, so with a new clutch should be spot on.
- Spartanx5
Oil leak fixed, new tyres and wheels on. No more trans fail safe prog!!!! next problem or maybe not a problem, at slow speed I can hear the brakes rubbing sounds like rears and on turning sounds like fronts join in to. Is this sort of normal?
Chrisw4266
Well clutch changed and refitted CDV as it felt weird with the new clutch. However in true fashion osf door handle carrier broke yesterday. So repaired with cable ties using the guide on here and new carrier collected from BMW yesterday might get it fitted today if I finish work on time.
