E53 indicators - 3 flash from a press - it is possible?
Having got used to driving cars which give three indicator flashes from a quick flick of the stalk, is it possible to program on the E53 series electronics?
The iDrive equipped cars have it as an option now and having put an earlier Mk4 equipped car with no iDrive back on the road I wondered if anyone has come across the function buried in the systems? If so where, and what was needed to program it? Scanner 1.4.0 or something more 'serious'.....
Never anthropomorphise computers. They hate that.- pvr
Re: E53 indicators - 3 flash from a press - it is possible?
Works via Intravee though, that is what I had on my M with the MKIV.
911 50th anniversary -
- Steamyrotter
i think you can on some versions of the LCM
But not sure if they are retrofittable (??!?) to all..
I know there was one you could use to get the corner light arrangement working (Fogs on when you turn) but cant remember the version or if it would fit the E53...
Please note...
Please note...
OK. Not going the Intravee route so will have a look at the scanner to see if the LCM will tell me anything.
Raj
As far as I'm aware Rich it's not possible.
Oh well.....have to 'relearn' the stalks then. Or follow the rest of the BMW owners around here and not bother..
Never anthropomorphise computers. They hate that.- Sanj
Get an Intravee
Need a job first!
Zakbelle
didn't think you could still buy Intravee??
- Sanj
August is the indicated time on the website...
X MAN
On E46 models you can change the LCM to a later software version 4.0 or above for this function to work.
Any other models of the era require a intravee as far as I'm aware.
05 X5 3.0d
Mods:H/s wheel.F/mirrors.Lumbar.Compass-remote r/v mirror.Rem ctrl.Bins holder.T90 Telestart.20"168's.Arches.Titan grills.Skid plate. P/O load floor.R/seat e/b/rest.R/blinds.H/rear seats.is r/bumper trim.chrome dials.car key mem.intravee.DSP.RV Cam.Dbl glazing.Ski bag,Rear blower
As it's a 07/2005 built E46 that's handy. Any way to tell which version is already loaded?
This probably needs to be in the 'other marques' section now..... :-[
X MAN
You may be able to get software version from BMW scanner 1.4.0
Click on LCM and at the top of next page you should see the SW version along with UNIT NAME , BMWTNR and so on.
INPA will also give you similar info under identification
Failing both above just pull it out (no need to disconnect) you'll find a sticker with SW version on it.
I think mine is something like SW 3.11 .
05 X5 3.0d
I'll have a look once the weather improves. Cheers.
Moved the topic ...
