E53 wheels on E70
Pradaman
E53 wheels on E70
Post by Pradaman » Tue Jun 24, 2014 9:11 am
Quick question, will 19" E53 wheels fit on an E70 3.5d sport. Needingy wheels painted and need wheels to use the car when other ones are getting painted.
sid10
Re: E53 wheels on E70
Post by sid10 » Tue Jun 24, 2014 9:30 am
hi no they have different centre bores 74.1 on the E70 , 72.6 on the E53
  E71 X6 wont fit either as they have different centres front to back 74.1 fronts , 72.6 rears !
Pradaman
Post by Pradaman » Tue Jun 24, 2014 9:54 am
That's a bit of a pain
RenoHuskerDu
Post by RenoHuskerDu » Tue Jun 24, 2014 3:05 pm
[quote="sid10"]
Hmm. My winter wheels came off an E71, so I had better test fit them soon.  I'd be very surprised at the dealer sold me the wrong wheels.
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
Post by X5Sport » Tue Jun 24, 2014 4:58 pm
You'll need to machine the rears for them to fit, so yes the Dealer has sold you the wrong ones.  The E71 has a completely different rear drive system (with electronic torque distribution controls) to the E70.
You can go E70 to E53 by using Spigot rings all round, and even E71 to E53 with spigots on the front.  But not the other way around.
RenoHuskerDu
Post by RenoHuskerDu » Wed Jun 25, 2014 10:31 pm
You'll need to machine the rears for them to fit, so yes the Dealer has sold you the wrong ones. [...]
Is there a thread out here which details the needed machining? We do have a prototyping machine shop at the factory. I guess I should introduce myself properly: www.dangel.com is our family company. I don't work there anymore but was marketing director for a few years.
Post by X5Sport » Thu Jun 26, 2014 9:54 am
You just need to machine out the centre bore to match the drive shaft end.  Take it from the 72.6mm to 74.1mm.  Not much needed, just carefully increase the centre bore dia by 1.5mm and keep it concentric with the overall centre point.
You'll need a big chuck to hold the wheel steady, or a decent size milling machine that can cope with that.
As always, measure three times and cut once!!
RenoHuskerDu
Post by RenoHuskerDu » Thu Jun 26, 2014 10:18 pm
Yes, we have a large CNC mill and a few lathes. The mod should pose no problem.  I'm grateful to learn of the issue before I find out on a frosty November day!  :xmassad:
RenoHuskerDu
Post by RenoHuskerDu » Fri Jun 27, 2014 8:22 am
I pinged a German BMW forum and got an answer that the X6 starts on 19s as base equipment. It didn't come with 18" wheels, so my wheels probably originated on an X5.  I'll just measure the center bores to be sure.
sid10
Post by sid10 » Fri Jun 27, 2014 9:22 am
hi check the part numbers on the back of the wheels on alloywheelsdirect as they did 19" alloys in various styles & sizes for both X6 & X5 !
Post by X5Sport » Fri Jun 27, 2014 1:33 pm
[quote="RenoHuskerDu"]
Correct.  19's were standard with 20/21" upgrades.  I specced 20" 214's on mine.  My winters are 19" staggered.
RenoHuskerDu
E71 wheels on E70 (note subject changed)
Post by RenoHuskerDu » Wed Jul 02, 2014 7:56 pm
I tried to measure the center hub bores but can't get my micrometer in there fully, so the measurement is imprecise. It seems to be just under 74mm. That might be due to accumulated winter crud from the PO running them on an X6 with no centering shims.  The PO was running them on an E71 but I don't know if he in turn had purchased them used from an E70 owner.
Does anybody recognize these 18" wheels as originally from an X5?
The casting numbers say "BMW 6 770 200" and "Ronal 1640"
Post by X5Sport » Wed Jul 02, 2014 8:51 pm
That part number is for BMW Style 209 wheels from an E70.....so you should be fine.  Not even listed against the X6 - which tend to be 19".
Realoem reference page.
RenoHuskerDu
Post by RenoHuskerDu » Thu Jul 03, 2014 4:14 am
Thanks!
kenniff
Post by kenniff » Fri Jul 04, 2014 1:10 pm
One final suggestion: try fitting one before you NEED to. Better to find out now.
Current: M50i arctic grey (G05)
Previous: RRS P400 HST, F15 M50d,F15 30d Msport, E70 35d Msport, 530i, Boxster, 330Ci Sport Vectra GSi, Chevrolet Lumina, Vxl Astras
It'll be allright in the end. If it isn't allright it isn't the end
