Service and gearbox service
Lloydy
Post by Lloydy » Tue Jun 17, 2014 9:45 am
Just had inspection 2 done on the motor and also got gearbox oil and filter changed.
What a difference! So much smoother in gears now and no more lurching!!
Also got front pads changed as they where pretty low :(
Need to get some pics up of the motor really as well
moar
Re: Service and gearbox service
Post by moar » Tue Jun 17, 2014 9:49 am
What year?
If the lurching comes back gets the transmission updated  :)
Don't go to the dealer, go to an Independent with Autologic. if dealer is your only option then ask for a flat rate fee to either update the car or ask a one a off quote to update the TCU.
cooa99
Post by cooa99 » Tue Jun 17, 2014 1:17 pm
Silly question, when would i know the gearbox oil needs changing?.
its a 2005 plate 3.0D and nothing in the service books shows it has been changed considering I have had the car now for about 6yrs
Current Cars BMW 2005 X5 3.0d ;  Golf 2003 1.9 TDI for the High Miles Journey to work
Zakbelle
Post by Zakbelle » Tue Jun 17, 2014 10:20 pm
If you check the forums unless you have issues with the gearbox most people say leave it alone. Whilst others say 60k, bmw say it didn't need attention as it's sealed for life. So I don't think that there is a definitive answer to that question. My gearbox seems to have good and bad days
Lloydy
Post by Lloydy » Tue Jun 17, 2014 10:33 pm
Mine is on 120k now and when they changed it they said it was black and crusty!
I am a believer in nothing is for life :(
Mine is a 2004 3.0D
Hopefully the lurching stays away but if so will get the update for it
moar
Post by moar » Tue Jun 17, 2014 10:58 pm
[quote="Zakbelle"]
Misguided advice.
ZF recommends the following from their own website:
ZF automatic transmissions are filled with specially developed oils. At very high operating temperatures, the oil ages faster than under normal conditions. Depending on the driving style (e.g., many trips at high speeds or sporty driving), ZF recommends a transmission oil change every 80 000 to 120 000 km, or after 8 years at the latest.
Zakbelle
Post by Zakbelle » Tue Jun 17, 2014 11:35 pm
Moar can you recommend anyone to do this work near Middlesbrough?
moar
Post by moar » Tue Jun 17, 2014 11:42 pm
I always recommend a fedauto garage if not the dealer.
This is one nearest to you.
http://www.ags-newcastle.co.uk/
andym3
Post by andym3 » Tue Jun 17, 2014 11:44 pm
[quote="cooa99"]
Im a great believer in getting the gearbox serviced! If your car has done over 60.000 miles get the gearbox serviced! Anything that has moving parts and takes oil, the oil does need changing!  8)
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
cooa99
Post by cooa99 » Wed Jun 18, 2014 10:13 am
[quote="andym3"]
My X is about 130k miles. I bought when it was about 53k miles so most of the mileage was 120miles motorway daily trip to work. After spending so much in fuel, I bought a golf MKIV to do the motorway miles and relegated the X5 to to weekends use from about 3yrs ago.
Any recommendations for somewhere down south (.. SE london/Kent)  to take for servicing?
cheers
Dimsum
Post by Dimsum » Wed Jun 18, 2014 12:27 pm
D&T Wise in Bexleyheath did mine. They are a Mini and X5 specialist. Owner is Dan. A top bloke.
Reusch
Contact:
Post by Reusch » Wed Jun 18, 2014 2:00 pm
Once again this has cropped up, do I don't I ,mines nearly at 90,000 04 plate.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Dimsum
Post by Dimsum » Wed Jun 18, 2014 2:19 pm
Did mine at 110k.
Had previously been done at around 60k I think.
Sent from my GT-I9300 using Tapatalk
cooa99
Post by cooa99 » Wed Jun 18, 2014 2:37 pm
[quote="Dimsum"]
I'll give them a go.  Last time I was there was with my 3 series when that address was BMWise .... talking about 8yrs ago!.
Dimsum
Post by Dimsum » Wed Jun 18, 2014 3:46 pm
Yep that's them! They changed the business name but they are still the same guys!
I've used them for years and always found them to be very knowledgeable.
