Parking heater remote start- Enabling
How-To articles ONLY go here.
BL02WAS
Post by BL02WAS » Thu Dec 09, 2010 7:58 pm
fish head, atleast i live in an area where they have street lights and piped gas!!!! lovely and warm..........im sure your family would disagree with you for what you have put them through these past few weeks!!!! rofl. there is nowt wrong with this beast.....
atleast i dont have to use old cans of rover spray paint to keep my car the way i want it......haaaa!! (lay off the gangsta jokes or i may hav to pop a cap in ur ass mitch!! be afraid! ( i do own a spud gun )
philip600
Re: Parking heater remote start- Enabling
Post by philip600 » Thu Dec 09, 2010 8:01 pm
2005 3.0d Le Mans auto - Now gone :-( but replaced with an Audi A4 Avant Quattro Black Edition 177PS :-)
1988 Porsche 911 Carrera Cabriolet - NOW SOLD.
1996 Lotus Esprit S4s in Mica Yellow.
x555
Post by x555 » Thu Dec 09, 2010 8:04 pm
@ blo2was ......I notice that since those wheels went on that next door has a for sale sign up LOL
ChewingBacca
Post by ChewingBacca » Thu Dec 09, 2010 8:06 pm
x555 and philip600 Thanks for the confirmation. Back to the head scratching. :headbang:
BL02WAS
Post by BL02WAS » Thu Dec 09, 2010 8:11 pm
very witty mitch but ylu are incorrect, that is my pad, im selling to buy something similar to your house with drive, garage etc!! hate parking on roadside!! ( but the better side of the bridge of course )
fenj66
Post by fenj66 » Thu Dec 09, 2010 11:06 pm
what is the circled red plastic grommet type thing? in the first pic?
BL02WAS
Post by BL02WAS » Thu Dec 09, 2010 11:08 pm
looking at pic id say its a bracket fastener on first glance
fenj66
Post by fenj66 » Thu Dec 09, 2010 11:22 pm
you could be right!
how does that fit into the play of things?..
ChewingBacca
Post by ChewingBacca » Fri Dec 10, 2010 12:11 am
It doesn't. Its the top mounting bracket for the heater.
lezmtaylor
Post by lezmtaylor » Fri Dec 10, 2010 4:19 am
[quote=""BL02WAS""]Les is there any chance you could put up a picture with notes on what pipe you slackened and also which wires to tap onto the separate battery and relevant terminal flash??? Much appreciated if possible[/quote]
Mine is fitted to the boat and is an eberspacher, but the same principles apply .
you need to find the tic tac pump(fuel pump) and then slacken /remove the delivery side pipe.,the 2 leads going to it can be bypassed to the jump lead pos & neg and then rapidly touched to the pos conn, if it tics it is working and will eventually pass fuel.
If the pump has been starved of fuel and pipe is empty, it takes too long for the pump to pump up fuel and the time taken is longer than the start up period for the initial start up cycle and the unit cycles down.
And Mitch you are dead right re photos.
I have a webasto unit in the garage somewhere off an X5 will have to test it and if ok flog it, it is no use to me as I have petrol X5 ( when the weather improves).
Lez
mcc05
Post by mcc05 » Fri Dec 10, 2010 9:51 am
[quote=""mcc05""]ChewingBacca
Ok checked my air con unit part number is 64116916646, with acording to RealOEM, same as yours not the one for cars with aux heating, which as mine works leads me to think that the diff part number only indicate coding data.
As for unplugging the valves, I got errors but not the same as the one you get (I got left/right valve error), this could be because the valves are totally not there so can't report back an error. I would think is your case the valve unit must be reporting back a failure.
Mark.[/quote]
RE : "21 [033] parking heating locking valve . latent heat storage system . cut off valve"
As I could not reproduce this error by disconnecting the water valves , I did some more digging and traced the AC wiring diagrams online.
Turns out that even though I can't find this on any RealOEM picture or confirm its on my car, as it looks like an underneath the engine bay trip and its raining here, theres apparently a locking valve controlled by the AC unit for independant heating that switches the water flow I presume to only parking heater function.
I wonder if this could be the source of your problems.
(Taking my X5 in the garage Monday to do a rear bush replacement, so if I get time will take a look for this mysterious valve, pull it an see what error I get.)
X5 3.0D Custom black carbon fibre edition
mcc05
Post by mcc05 » Fri Dec 10, 2010 9:52 am
[quote=""BL02WAS""]fish head, atleast i live in an area where they have street lights and piped gas!!!! lovely and warm..........im sure your family would disagree with you for what you have put them through these past few weeks!!!! rofl. there is nowt wrong with this beast.....
Sent from my iPhone using Tapatalk[/quote]
Love the wheels, just like mine :driving:
ChewingBacca
Post by ChewingBacca » Fri Dec 10, 2010 10:34 am
Nice work Mark.
OK pin 2 is involved with this. Tried to trace the brown and white cable but lost it in the harness.
A similar wire goes to the valve under the Webasto but it looks a little thicker.
I will get the meter out over the weekend.
BL02WAS
Post by BL02WAS » Fri Dec 10, 2010 12:53 pm
thanks mcc, yep 22"'s of kahn finest!! lol. well i was going to spray my 19's like yours, but then these came up, yours looks smart too
pvw10
Post by pvw10 » Mon Dec 13, 2010 9:46 am
[quote=""x555""][quote=""rconwa11""]excellent. i want one lol. knowing my luck every day would be a flat battery day. i drained the battery today just fitting my dvd player.[/quote]
Turn off the boot light when working in the back there fella and the interior lights aswell :thumbsup:[/quote]
How can you turn off the boot lights, plus all the others ?
