Parking heater remote start- Enabling
Hi all had a chat with a webasto service engineer based in Bristol today. Told him about my issues, said it could be a number of things and a good service would do the trick. He was kind enough to forward me a PDF file used only for dealers of webasto showing exactly how to strip down etc etc and very good explanations diagrams etc, very informative. 47 pages for the webasto thermo top x unit. If anybody wants a copy pm me your email address and I will forward it on.
Re: Parking heater remote start- Enabling
ChewingBacca
[quote=""ChewingBacca""]
Indeed there is quite a difference. What is that in the foreground of pic 1 that I don't have on my '04 diesel?
I would appreciate if you could recreate the error as this will greatly help diagnose my problem.[/quote]
Ok checked my air con unit part number is 64116916646, with acording to RealOEM, same as yours not the one for cars with aux heating, which as mine works leads me to think that the diff part number only indicate coding data.
As for unplugging the valves, I got errors but not the same as the one you get (I got left/right valve error), this could be because the valves are totally not there so can't report back an error. I would think is your case the valve unit must be reporting back a failure.
Mark.
Mark.
X5 3.0D Custom black carbon fibre edition
- ChewingBacca
I am greatful for the time and effort you have spent on this for me.
There are some BMW indies in my town. I will find time to let them look.
Thanks.
Thanks.
My parking heater wasnt working so ive had it replaced under warrenty
it now works when the car is running - i can hear it shutting down when i take the key out etc
it doesnt however activate setting the timer or ticking the "direct" mode on "aux heating"
sometimes the a/c unit lights up like its woking but stops after 2 seconds
any ideas?
Scanning the can for faults in the a/c section it says
"21 [033] parking heating locking valve . latent heat storage system . cut off valve"
any ideas?
- ChewingBacca
[quote=""t400""]any ideas?....[/quote]
Go back to page 12 of this thread and read on from there.
apologies, should have gone to specsavers ( how did i miss that)
anyway i have aprt number 6.972.163
does that mean i need a new thingy?
Les is there any chance you could put up a picture with notes on what pipe you slackened and also which wires to tap onto the separate battery and relevant terminal flash??? Much appreciated if possible
Also, I could surely just slacken pipe and run webasto and just engage the webasto surely. Wouldn't hurt it I would imagine??
Lez ....photo's.......you got no chance
Anyway it's about time you lot got these webasto's working instead of all this ....the weather will change before you lot get it sorted
you havent said if urz is wrking yet???
[quote=""BL02WAS""]you havent said if urz is wrking yet???
Sent from my iPhone using Tapatalk[/quote]
You know mine is working fine i told you the other day fool
- ChewingBacca
[size=99px]OK, perhaps the question that needed to be asked from the start.
The OP and mcc05 have the engine with the "fuel filter and fuel cooler" shown in Pic A
Has anyone actually got this mod working with the engine that does not have the "fuel filter and fuel cooler" as in Pic B?[/size]
[size=99px]-[/size]
[size=99px]The pics are for reference only. I am not suggesting this component has anything to do with the heating system what so ever.[/size]
[size=99px]-[/size]
you said you drained battery in previous post gonk!! plus dont be too sure. i may pop down to the broad of moor and sabotage your webasto!!! or just swap it with mine
[quote=""BL02WAS""]you said you drained battery in previous post gonk!! plus dont be too sure. i may pop down to the broad of moor and sabotage your webasto!!! or just swap it with mine
I had a slight drain from working on the car not a total drain so after a few runs it's fine and working spot on hhhhhhmmmmm nice and warm
BTW we don't allow fish-heads over this way ....and like i said the other day you should have bought a decent car instead of that bag o shi@e gangsta lookin rubbish ....i mean you've only just got it to turnover properly now
[quote=""ChewingBacca""][size=99px]OK, perhaps the question that needed to be asked from the start.
[size=99px]-[/size]
[size=99px]The pics are for reference only. I am not suggesting this component has anything to do with the heating system what so ever.[/size][/quote]
Yes.I don't have the same as pic 1 and mine works fine with the maplin type mod as done by the old one.
This is mine and a close up of the webasto if it helps
[size=99px]-[/size]
